Blower motor slows when braking...
bowtiefreak
No Quarter
Near Philly
Ok weird issue and I'd like to hear some feedback on where to start chasing.
This is my 1997 tahoe. When the blower motor is running, usually low speed and I hit the brakes I hear the fan speed change. This only happens when the truck is in motion it seems. It does not appear to do this when sitting still. Ideas? Battery is new and was doing it before then. Alternator has some years on it. I notice no other electrical current draining types of issues. Is this a motor or resistor problem?
So?
bowtiefreak
bowtiefreak
No Quarter
Near Philly
I could try too. All I know now is it slows pretty good and then comes right back
SunlitComet
OBS Jedi-Do Good
unknown at this time.
please try. need the data. this happens when slowing down so is this just coasting or when you press the brakes? aside from he ht383 in there the charging system and power distribution system is still relatively obs?
bowtiefreak
bowtiefreak
No Quarter
Near Philly
All is stockish other than drive train. It only happens when I hit the brakes, coasting does not do it. It is down right now getting ready for some exhaust things to happen so I have not touched in in a bit
SunlitComet
OBS Jedi-Do Good
then i would suggest that the brake light system is drawing excessive current lately that may be sucking power from the rest of the system or a ground common to the two systems may be damaged by corrosion or looseness.
bowtiefreak
bowtiefreak
No Quarter
Near Philly
Nope, never touched it. Truck hasn't moved in a while. It will be a spring project for me I think.
jeremylentsch
