Blowing black smoke when flooring accelerator
moviewithnotitle
Jersey
I have something similar to this. It's not black smoke, but some black. It happens on WOT, at high RPM's. Picture launching out of a toll plaza and getting up to 70 ASAP. This is the ONLY time that I would get this condition, normal driving never. I have seen new cars do this as well under heavy acceleration, so I have never been concerned.
I would think that if you noticed a change in MPG, sluggish acceleration, tough starting, misses etc, that you could have a bigger issue that is causing what you described. I don't have any of that, I have had my truck maintained regularly and it was tuned up within the last year, so I have not been concerned about it. Best I could think is that some oil is getting into the cylinders, but never enough to cause a concern. I change the oil at 5k, and it's never below the optimum range for oil.
L
LVNeptune
^^^^ exactly what I was thinking.
I figured there had to be people in the same situation and I too have seen newish trucks do the same thing and they are definately not diesel.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
That Delphi spider should be the only bang you should ever use period. It will have a new fuel regulator already installed. you will need to get a hold of scanner with live data view and I should be able to get you the values on what you should see. Any chance your vehicle may have been previously tuned performance wise?
L
LVNeptune
Doubtful it was ever tuned. Any android/iPhone data viewer you can recommend ?
NOVAhoe
Manassas, VA
my stepdad always told me it was from carbon buildup in the combustion chambers thats burning off at higher rpms, mine used to do it, but after my tune and now that my foots always down i havent noticed it at all haha
L
LVNeptune
With that logic wouldn't it eventually stop if I continuously forced it?
L
LVNeptune
Also update: there seems to be a lot of water coming out of the tailpipe. Clear water doesn't look like coolant. May or may not be related
L
LVNeptune
It made a puddle and I grabbed some of the water and it had carbon deposits in it lol. The water is cleaning it out.
Thinking about it, it might be when I backed into the lake a few days ago, it might have been stuck in the muffler.
mrkkrnr
