Boats and Hoes, Gotta have me some boats and Tahoes
89Suburban
Bull in the china shop
SE PA
Memorial Day on my boat
89Suburban
SE PA
Hooking up to the boat last night (Look at dat ***) and on the river pic. And that backup camera under the bowtie there (little black thing), perfect ball alignment when backing up. :chewie:
EfiniMotorsport
Probably the crappiest pic of both my truck and boat but all I have right now. This was the first ttime I'd ever had the boat in the water. I bought it cheap and redid the entire interior, almost all the wiring and dropped in a fuel injected 4.3. If you want to see the whole build it's here https://forums.iboats.com/forum/engine-repair-and-maintenance/omc-i-o-inboard-engines-outdrives/10562245-thought-i-d-show-off-my-new-build[URL='https://forums.iboats.com/forum/engine-repair-and-maintenance/omc-i-o-inboard-engines-outdrives/10562245-thought-i-d-show-off-my-new-build']ew-build.[/URL] It's pretty extensive and although the maiden voyage wasn't as good as I had hope it could have been a whole lot worse
89Suburban
SE PA
Probably the crappiest pic of both my truck and boat but all I have right now. This was the first ttime I'd ever had the boat in the water. I bought it cheap and redid the entire interior, almost all the wiring and dropped in a fuel injected 4.3. If you want to see the whole build it's here https://forums.iboats.com/forum/eng...es/10562245-thought-i-d-show-off-my-new-buildew-build. It's pretty extensive and although the maiden voyage wasn't as good as I had hope it could have been a whole lot worseView attachment 225826
Hell of a project, good luck ironing out the bugs. Keep us posted!
EfiniMotorsport
I've put about 40-45 hours on the boat so far this summer. She runs great. Only issue so far is the belt sheared a rib off as I've had some tracking issues with the larger alternator. When it broke it took out the pcm coolant temp sensor. Boat still runs fine and with one less rib it tracks fine. I keep a spare on board jut in case and it take about 2 minutes to change.
LM7Tahoe01
I’ve got a 12’ aluminum boat with a 10 horse evinrude from 1959, I’ll have to get a pic the next time I take it out…
ElMasBuscado23
