Body Lift vs Suspension Lift!!!!!!!!!!!!!!!!!!!!!!!
jmildoc
jmildoc
Indianapolis,Area
i can just see myself looking for some 8 lug 24''s that would really go over well with the wife.... we already have a car that has wheels that are too big for it...... plus its a 3/4 ton and I tow alot and want to be able to go off road cause the explorer doesnt take me there....
southbar
just put "the poor mans lift" on my 05 2 weeks ago. so far so good. no rattles or rolls at all and it drives exactly the same as it did 3 weeks ago.picture.jpg
Modded
That Guy
Haha Jmildoc your sig pic is way too big, I thought it was a pic in a thread whenever I'm clicking aroudd the forum, just noticed it was a sig!
Modded
That Guy
Forgot I posted here Jmildoc, looks like you fixed it though!
02TahoeMD
somewhere on the road
Poor mans lift - get yourself a set of Ford F150 torsion keys. Yes, FORD keys. They fit just fine, and only run about $26 each. Swap the keys out and you can crank up the front end to be completely level with your rear.
Spend about $50 more and get a set of coil spacers to lift the rear and crank the front keys more and you can stuff a 33 inch tire under your rig.
If you have an LT get some Z coils to add about a half to 3/4 inch more height.
If you want to know more, I did a detailed writeup of my suspension work here.
As for body lifts, I think the smallest you can get for a NBS is a 3 inch body lift. But, as mentioned, it is lots of work to do, since you are separating the body from the chassis.
Of course, if you want to go even taller, then you will HAVE to go the route of a suspension lift kit. Usually starting around $1600 or so for a 4 inch lift and up....which is why I wen the cheap route to get about 3 inches of lift.
09YukonHybrid4x4
