I’ve been dealing with a random popping sound from the front end of my 2005 Tahoe (Z71) and everything is tight with the suspension. It’ll do it when getting out of a parking space as I turn the wheel, which made me thing tie rod or ball joint. Then I came across the two front body mount bushings.
The lower halves of the two front bushings are loose, as shown in the video above. The bolts are tight.
Body mounts are foreign to me, but I’d wager my paycheck that they are not supposed to be that loose. From what I found online, the torque for the bolts should be around 44 ft lbs (please confirm).
Does anyone have an OEM part number for the bushings? I couldn’t find it on the ACDelco website. RockAuto shows 15201791 but is labeled as radiator support and as a body mount. I also see 2924040
Which part number do I actually need for the front body mounts (just behind front wheel well)?
Or would I be better off converting to poly? If so, what part number is best?
Thanks!
