body work!
rayninglead
Michigan
Starting the little bit of body work I need to take care of was wondering a good place to buy replacement panels from? I only Need drivers lower rear quarter panel. After body work I'm going to be rhino lining the underneath and rockers and wheel wells also looking for a good product for that too any help would be appreciated.
jerryjoe28
That Guy
cabot AR
i would check LMC and Raybuck for the panels...... as far as the liner ive had good luck out of my Raptorliner
R
rayninglead
Michigan
Is raptor liner easy to do yourself? I was looking at monstaliner but I looked into raptor liner but didn't know how hard application was Any more info would be appreciated
jerryjoe28
That Guy
cabot AR
it was very simple just poor the hardner in the premeasured container. shake it up and your ready to go ( also add color if you want it anything other than black)
---------- Post added at 09:25 AM ---------- Previous post was at 09:24 AM ----------
i use to paint for a living but i honestly think it would have been better if i knew nothing about painting. the liner is more like coloring than painting lol
R
rayninglead
Michigan
Ok thanks I'm probably going to go that route than so I can get into corners better, how thick is it? how much can the raptor liner cover?
jerryjoe28
That Guy
cabot AR
it is as thick or thin as you want it to be. if you want it thicker just slow down you gun some and do more coats..... coveraged will depend on how thick you go. i did my entier truck with 3 gal (3kits). and had one quart left over for touch up. i have sense went over it with another kit to kind of level out the texture. after you first good coat the rest cover VERY well
R
rayninglead
Michigan
Thanks sounds like I'm definitely going that route only doing my rockers bottom of doors and wheel wells wonder what kit I should get
kjetilaf
