What wideband you planning on running JK?
Just gives me an excuse to drop in a built 6.0
But really, I'm not too worried about it. The tranny will go before the motor. I'm ordering a Stage III trans in a couple weeks.
The boost portion won't read with out any added pressure. The vacuum portion will read due to the way a n/a enigine works; the pistons draw in outside air creating vacuum.Pics of it at night!
I thought a Boost gauge won't read until there is some sore of fi.
If you wanted the needles to match should have gotten Cobalt Series. Out of curiousity, how did you change the color? Sodder or replace a bulb?
The Level III I'm ordering is good to 650hp. I thought about a 4l80, but I didn't want the higher first gear.once you pulley down you'll wish you opted for an flt level 5...unless you're doing a 4L80 swap
