Trailblazzin
Chevy Spacers, Silverado, Suburban, Tahoe, Sierra, Yukon 1/2 Tons. I had these on my Tahoe with factory wheels, made the rear and front track width the same.
6x139.7 Bolt Pattern, 77.8 Hub. Aluminum, BORA Black,
2 @ Thickness=.75in (19.05mm)
2 @ Thickness=1.25in (31.75mm)
$200 for all 4.
These BORA Aluminum Truck Wheel Spacers push the wheel out from the hub to provide a wider stance and will fit perfectly on your truck/SUV as if it came that way from the factory. Built hub and wheel centric (when applicable) to ensure a perfect ride every time. These high grade spacers are built using only the best U.S. Alcoa 6061t6 billet Aluminum, right here in America. All BORA parts are Anodized Black for corrosion protection. Mounting hardware is included.
$200 for all 4.
