Both left and right brake lights not working, third brake light works
GREGB1954
Just as the title states, both the left and right brake lights are out but the 3rd brake like works. I just changed one lamp about 6 months ago and admitedly I have not checked the bulbs other than I did remove and reinsert. Is this a known problem with an obscure solution?
Tonyv__
Bucks county PA
I mean you can chase all your grounds and drive yourself crazy or just go the simplistic route and change the bulbs first.
I’ve had bulbs fail shorter than others.
TollKeeper
Brighton, CO
This was a fairly common problem on the GMT Vans, which I believe still use the same style of system. The issue for them revolves around a faulty turn signal switch.
If I am remembering correctly, the way to test it is to just turn on your turn signals... If I am remembering correctly, they use the same bulbs as your brake lights. If the lights turn on for turn signal, but not brake, than its the turn signal switch.
easiest thing to do is a grab a couple bulbs for $3 and swap them out.
THEN, if no go proceed to other possibilities
no reason to presume anything else.....
will take a whole 5 minutes of your day
Multnomah Falls
Is there not a separate fuse for the left and right brake lights and the third brake light, also called high mounted brake light? To me, it makes no sense for all bulbs to go bad at same time. Could be the t/s switch but check for separate fuses.
G
GREGB1954
Problem solved. I'd like to say that I performed some brilliant episode of deep electronic analysis and replaced a 20' harness that weaved from the engine compartment into the dash, which I had to R&R, through a channel in the body all the way to the rear of the vehicle. But being that I am an honest guy, I replaced 2 defective bulbs for $12 and solved the problem. I was going to do that before I submitted this thread but thought the odds were too remote that both went out when I had just changed one 6 months ago. One key thing to remember though is to NOT touch the bulb glass with your skin. The oils will damage the glass and shorten the life, which is probably what I did.
Aren't the bulb globes all plastic now?
Multnomah Falls
Great. Yes, try to not touch any bulb surface.
Mejo
