Bowtie questions
RST Dana
OH
Anyone replaced the rear? How difficult is it? I want black ones.
I’m planning on lighted front bowtie. Any suggestions?
KMeloney
Lighted front bowtie...as in where did you purchase and are you pleased with the result
Ah, ok. Does anyone even offer an aftermarket one? Regardless, I'd go OEM, bar none. Check out a site like gmpartsdirect.com if chevy.com doesn't have them available.
RST Dana
RST Dana
OH
Ebay, rear is easy, front requires a b it more skills ans youtube.
Vladimir2306
The front emblem can be changed very easily, about in 15 minutes.
RST Dana
RST Dana
OH
Knowing what I experienced, I would bet money you can’t install the front either wiring in 15 minutes on a Tahoe. Just the emblem, sure, but not the needed wiring.
Vladimir2306
I put the emblem myself, you can break out the old letters with a screwdriver, it takes 5 minutes, and 10 minutes is to unscrew the front part of the left fender, disconnect the connector of the left headlight, and run a wire from the emblem to it)) only the upper bolts of the grill are unscrewed))
Loose_Gasket
