Brake Booster Bad???
FLHOE
Florida
Bad Brake Booster???
I have to push harder on the brake pedal to slow down the hoe. I looked underneath the dash and there was a drop of fluid where the pushrod goes into the booster. Also, when I push on the pedal while parked it makes a noise. There is no sign of fluid under the hood and the reservoir has fluid. Is the booster going bad? Any suggestions?
I have some shocks coming this week so I will bleed the brakes when replacing the shocks to see if that helps. I did replace all the fluid last year when I installed new pads and rotors, can't imagine the fluid is bad already.
cam3439
It does sound like your brake booster is going out. Have you checked for vacuum leaks to the brake booster? How many miles on it?
F
FLHOE
Florida
I think I have a hydrolic booster, is there a vacuum line?
It's a 2004 with 91,000 miles.
patniven
