Brake booster going bad?
Jaycenk
Florida
Just replaced all of the brakes on my 98 tahoe. Replaced wheels cylinders and the front calipers are good. Had some blow by on the master cylinder so I replaced it as well. Changed all of the rubber hoses as well. I have bled the brakes so I have a rock hard pedle when the truck is off but it feels like I have a problem with the booster or something when it is running. I have a pedal that changes BIG time based on vac. When the rpms are up at say 1500 to 2000 and I jump off the gas and on the brakes I have a great feeling pedal. Nice and firm and little travel. When I let it idle while coasting and then hit the brakes it is a hell of a lot softer and travels further before having stopping power. Pumping at this point will do nothing. If I blurp the gas and jump back on the brakes I have a good pedal again and it stops on a dime. Is the booster bad or is there another culprit? I am having trouble figuring out where to start looking. Thanks for the help
95slowhoe
Boon
When my booster went bad in my hoe i had a super hard petal and the hard i pressed the pedal the more the brakes applied. I found it was bad by rolling up the windows, turning off the radio and blower motor. Then i pressed the brake pedal and heard a faint hissing sound and knew it was bad.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
best way to confirm, get a vacuum or mighty vac with a gauge, If it dosent hold, you have a leaky master
Jaycenk
Jaycenk
Florida
K thanks for the reply's I will try listening for the constant hiss and If I can't hear it I will put a vac gage on it and double check it.
QUYHMK
