Brake caliper recommendations
yukonjacks
A Vegitative State
The Confluence
Im ordering the 5 line ss brake kit from summit. The local brake shop said that the bleeders on the calipers are real rusty and the hose fitting on the P side front is not in good shape. Rather than snapping shit off Im thinking about replacing the calipers. Should I risk a junk yard for oem or buy new. Not sure what new ones to purchase.
Any suggestions would be greatly appreciated
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
use a torch and ice to thermal shock them so they break free.
then you don`t have to replace anything. :)
Otherwise, used. no brainer.
yukonjacks
yukonjacks
A Vegitative State
The Confluence
Used that method in the past disassembling steam valves. not always successful, even used coca-cola. I just dont want to be stranded. I would rather be prepared. Ive already replaced two brake lines due to corrosion.
dropmech
Puddle Pirate
Coral Springs
It doesn't cost more than the price of admission to at least go check out a junk yard. See what you can find.
Eagle
EL PASO, TX
yowza.
coca cola sucks for the record. use something with some real acidity and cleaning power, like CLR. that is what I use to de-galvanize (and sometimes de chrome) nuts and bolts.
use a line wrench or 6 point socket and try tightening first then shocking off or hammer/airchisel for vibrations.
I'd locate a caliper, and only go buy it if I needed it.
On the other hand with a set of spares you could always do the job and then see about disassembling and Powdercoating the originals if they come off intact. :)
RE SS lines:
make sure you are using stress relocators to move the pivot point away from the fitting (like they use to pass DOT tests), or else those plastic brake lines you are buying will fail right at the fitting from fatigue.
they are recommended to be replaced annually or bi-annualy if you live in an area where you experience problems with corrosion. :)
fullcourt24
