When you own a 20+ year vehicle, you need to expect that you will at times need to address issues that randomly pop up. Yesterday, after work I fired up my baby, put it in gear and started to drive off and after pulling out of my parking space for about 100 yards the ABS light came on. Pulled over, shut the car off, popped the hood just look at any wire bundles I could see. Nothing obvious. Got back in car, turned the key on and check my dash lights. All was normal. Started the car and the ABS light was out. Put it in gear, light stayed out. Started to drive off and the light came on again. Brakes appear to work fine even through hard braking. Assume antilock brakes would not. Did not brake hard enough to check that out. Got home, hooked up my scan tool and received the following error codes: C0265 - EBCM Motor Relay Circuit and C0268 - Pump Motor Circuit Shorted. I guess I will start by looking at the wiring. Any other thoughts/suggestions?
