Brake Controller
Black Limited
Welcome to the forum from Oregon. Someone will chime in with help.
We recommend that you put all your rig(s) info in your signature so we all don’t have to guess at year, make, model, engine size, trans, rear axle locker…….etc. While you may have posted pertinent info in your first post, you may forget to do it again and the info is needed by us anyway. Makes it way easier on all members that attempt to help, to have that info right up front. It is also recommended that you take a pic of your RPO codes, on the inside cover of the glove box, and post that image in your signature. All this info will greatly help those that will try to help with a problem.
If there is any other info, like upgrades, mods or recent mechanical/maintenance work done, that would be helpful in any post as well. Too many times a question is asked by the poster and after about 10 responses we find out that the poster has done recent work to attempt to fix the problem or work that was done that SEEMS not related to the problem.
Thank you...…………..all guesses till you have the right data.
CMoore711
Black Limited. It’s obvious you did not even read PNW VietVet’s post before posting your comment.
PNW VietVet makes zero guesses or even recommendations specific to the OP’s question at all. In fact he’s advising OP (and all members for that matter) to make sure to post all of your vehicle details, specific factory options, any aftermarket upgrades or mods installed etc on your vehicle when posting on the forum requesting advise, help, input, or direction for any owners specific situation.
OR VietVet
Multnomah Falls
Military
Willamette Valley
If we could get every member to post that info and keep it updated it would remove so many of the back and forth posts trying to get the info and will help expedite results. As a former service manager, I always started out with these types of questions and many more.
