I think he's talking about this.Brake fluid pressure sensor or proportioning valve?
brake pressure modulator valveBrake fluid pressure sensor or proportioning valve?
Do you have a part number? Did you look on Ebay?brake pressure modulator valve
Typically it is called a ABS pump, you can find them at the junkyard or ebay, LKQ, etcbrake pressure modulator valve
What are the brake codes off the SPID label?The shop is a NAPA shop, so they won't work with used parts. They were not concerned about keeping the brake fluid reservoir filled and just keep on driving.
I don't have a part number because there are several part numbers when I search, and I can't confirm which one is for my vehicle . . . 2004 Escalade ESV Platinum AWD 6.0 liter.
