Brake issues
clemet
Norfolk VA
So here's the deal. I am navy and not home. Right before I left I changed the rear pads in my wife's 03, and everything seemed good. She didn't drive much before I left. After leaving she drove it a bit, and had the engine light come on at random. 2 days later at random the engine light and abs light came on. I have replaced the left hub cause it was worn out, but the right seemed tight. I had her check the connection to the right front sensor, and she said it had some play, but not a lot. Here are the codes that Advance Auto pulled from the PCM for her (my code reader is on loan).
C0238 - ABS wheel speed mismatch
C0223 - Rt front wheel speed signal erratic
C0237 - Rear wheel speed erratic
C0236 - Signal missing
So nothing that I can see in common other than maybe a ground, but I would think that it would set more than those if it was a bad ground. I also have a constant knock sensor code even after swapping the sensors, but that's another story and above her level of repair. Thanks for any advice.
