Brake line diagram - SOLVED
S
shegarty
Looks like this: https://www.rockauto.com/en/moreinfo.php?pk=1416050&cc=1424191&pt=679&jsn=939&jsn=939 ABS Modulator Valve
The other choice does not look the same and if is the other choice you would have a JL4 RPO code. That would mean you have active brake control and would likely have the master cylinder with a spout out the front of it. Mine has all that with the hydro-boost system.
Is your rig a 1/2 ton or 3/4 ton?
1/2 ton ... that looks like the part but I just need the line that runs to it from the dist block. I got a kit that I'm going to check to see if it contains the right hose.
GMT800 SUV/Trucks
I looked and looked for the line/hose from that ABS Modulator Valve but could not find. That 8 digits should get @915_Tahoe's attention. He will be the one to help you. I am going to look at GM parts too and get back to you.
S
shegarty
I was able to find the hose in a kit. I'll take out the other two short hoses from the master to the dist block. Got the hose replaced but the braking system will not engage now. Lights on brake and Trac control as we as service brake system light. Too much air in the system? I filled the line before securing the connections. Aside from cracking a connection how do I bleed this?
Nothing shows up in a basic OBDII scan. Should I try a hard reset by disconnecting the battery?
S
shegarty
GMT800 SUV/Trucks
    15181253
    PIPE, FRONT BRAKE COMBINATION VALVE
    • Fitting Vehicle Options:
      CK1(06-36)(JH2)
    $65.44$34.68
    Add To Cart
    15181253
    PIPE, FRONT BRAKE COMBINATION VALVE(INCLUDES 3)
      CK1(06-36)(JH2)
    $65.44$34.68
    Add To Cart
    15181254
    PIPE, REAR BRAKE COMBINATION VALVE
      CK1(06-36)(JH2)
    $65.44$34.68
    Add To Cart
    15181254
    PIPE, REAR BRAKE COMBINATION VALVE(INCLUDES 3)
      CK1(06-36)(JH2)
    $65.44$34.68
    Add To Cart
  • *******************************That looks like these on the other link I sent you from GM Parts Giant****************************
TollKeeper
Brighton, CO
This will require a high end scan tool, you will have to activate the ABS pump, and continue bleeding. Its a long process. The entire system, all calipers, and ABS pump, and everything need to be bled.
S
shegarty
This is what I was afraid of. So it's likely a trip to a shop that can bleed the system for me then.
S
shegarty
I think all of these are for the master to dist block. Here's the offender here
Abelton
