Brake pedal removal
Yukongk
NY
I am going to replace the bushing that prevents the brake pedal from rattling over bumps. I need to remove the bolt that the bushing goes around, but I *think* I also need to remove the part that goes through the firewall. Can anyone shed some light? Anything I need to be cautious of?
Thanks
Yukongk
Yukongk
NY
Thanks
So everyone is driving around w a rattling brake pedal?
Bomba02
Mine does it, i want to :biggun: Its on my to do list! If you do yours make sure to share your adventure!
Billy
Yukongk
Yukongk
NY
I was poking around under there and the bolt size is 3/4". I'm going to try to remove it with wrenches bc it is hell to get a ratchet in there and try to turn it. Once I get the main bolt out, I think I have to remove the attachment to the plunger (piece that goes through the firewall). Then I should be able to slide the bushing in and re assemble. Very tight space to work....I was thinking of injecting silicone where the bushing goes to see if I can make it take up enough space and protrude out the sides to stop the rattle, but I'm not sure if that'll work and it'll be a PITA to clean out.
Mr.Jack
Norway
My pedal is making an annoying squeaking sound when pressed.
What to do here?
boozer
Wichita, ks
Mine rattles also, very annoying. I sometimes hold it with my foot to keep it quiet! Please keep us updated with the fix
Yukongk
Yukongk
NY
Well, I got tired of thinking about fixing it, so I finally did it!
Ok, I'm not good at writing "how-to" threads but I'll try.
Tools: Have a ratchet, adjustable wrench, long open ended wrenches, short open ended wrenches handy. The size is 3/4
Brake pedal removal, yes you need to remove the entire pedal for this.
1- Remove the retaining clip from the middle of the neck of the pedal. This holds a wiring harness and the rod that goes thru the firewall to the brake system. Don't lose this clip.
2- Slide on underneath and locate the nut holding the pedal in.
3- Reach up to find where the bolt begins. You really have to reach up in there.
4- Now that you have an idea where the head of the bolt is, slide a long 3/4 open ended wrench up there. Make sure the offset of the head it is pointing toward you and not toward the firewall, otherwise you might not grab onto the bolt. Hold the wrench from the bottom with your left hand and use your right hand to feel around for the head of the bolt and manipulate the wrench onto it...If you can't get onto the head of the bolt bc it needs to be turned a bit, don't worry.
5- Now that you have the wrench in position, apply pressure toward the bolt using your left hand, use your right hand to grab the nut with a wrench. When you turn it a little bit, the long wrench will grab onto the head of the bolt if you apply pressure correctly.
6- Have fun breaking your knuckles. Mine seemed to have a "thread locker" on it and it was very hard to break the nut. There is barely any room to maneuver, so I started with an adjustable wrench until I got down toward the end of the bolt, and then a shallow socket did the trick. It took forever to remove this bolt.
7- Once the nut is off, slide the bolt out and carefully remove the rod from the neck of the brake pedal (mentioned in step 1)
8-Remove the old worn bushing (I broke mine out with a screwdriver and pliers).
9-Insert new bushing by squeezing it and sliding it through until it clicks in.
10- Reassemble.
Notes: I cleaned the bolt and nut w WD 40 and putting it back on was a breeze. I used Blue Thread locker, but might take it off and use Red thread locker bc this is a brake pedal we are talking about here.
ehernande86
