Brake upgrade questions
retorq
Kingman AZ
I did some research ... if you are serious about the hydroboost setup on a 95 the 1 ton 2wd trucks had that as an option WITH REAR DISC BRAKES. You can get everything you need factory from the local autoparts store ... didn't check into other years but I bet they are the same way.
AtomicHoe094
Atomichoe094
cleveland, OH
if you want the hydroboost parts numbers for OEM shit, here ya go :)
gathered them up a while ago and been sitting on it
Hydroboost kit PN 178-578
master cylinder PN 174-722
steering box PN 36-0517567
power steering pump PN 36-517138
Hydraulic line from pump to booster PN 36-365470
Hydraulic line from booster to steering box PN 36-365480
Monstar_est87
Monstar_est87
City of Angeles
Would any one happen to have part numbers for the power slot cryo rotors..? Keep in mind The Limited is a 5 lug...
13JRomee
