Brake Upgrade
Red_Raider
Derby, Kansas
Hey guys looking for some info on upgrading my brakes. I have started to notice that the stock brakes and rotors are taking longer to grab to stop the 24s. I put new ceramic pads and Acdelco rotors on about 6 months ago. I really don't have the funds nor do I want to spend the cash on a big brake kit. I have someone local who is selling some 14" slotted rotors. So my question is will just putting bigger rotors on with the stock caliper make any kind of improvement?
ankeny, iowa
Idk the company but they make a kit that allows you to use a 1 or 2 inch larger rotors. While using factory calipers. I'm sure someone has more info on how much better your braking power will be
JKmotorsports
Austin, TX
Larger rotors alone will be a great improvement. This will move the caliper out farther from the center of the wheel, increasing leverage, making it easier for the calipers to stop the rotating force of the wheels. Keep in mind you'll need relocation brackets for the calipers if you upgrade the rotor size.
turq
Does anyone have any info on these brake kits. Would be nice to have better brakes without the BBK price
Pachanga02
Ny
Doin the GMT900 brake upgrade is pretty good. I upgraded to them and its great with my 24s.
Red_Raider
Red_Raider
Derby, Kansas
Yeah I saw your mod to the brake system. I was thinking about that too, but my local junk yard rarely has anything that new. Every time I check the newest GM on the lot is a 00 :lol: A lot of good that does!
sdkilla99
San Diego
ok, noob question. GMT900? I got to start looking for brakes so i need the education.
Big Buttons
The SS Burb
South Texas
GMT900 2006+ GMT800 2000-2006 GMT400 1999 and older
---------- Post added at 05:07 PM ---------- Previous post was at 05:04 PM ----------
And Red Im running R1 concepts cross drilled and slotted rotors with autozone ceramic pads and this heavy ***** stops well for having a 600lbs system, my fat ass, tool box, and other misc items. Can get all 4 corners for under $300 I believe. If you get them before the 28th of Feb. and use code CK15 you can get 15% off.
01Konvict
Boats n Hoes
Raleigh/SML
Get GMT900 front rotors, pads, and calipers. Then Russell stainless steel brake lines (5 line kit) plus convert to hydroboost. You wont imagine how much difference all that together does for these vehicles. It stops my yukon better then accord.
audley71
