Brakes are farting
M1Gunner
Gainesville, Fl
One thing to look at, not saying this will solve your issue, but get a scan tool and check your wheel speed data. If there’s one that’s cutting out at low speed, which gm wheel speed sensors are known to do, you’ll get an unwanted abs activation resulting in the symptoms you are having. Again, not sayin this is your problem but it’s just something to look into.
CamReynolds
CamReynolds
The abs seems to only come on at 10-0 mph so I'm hoping it's just a bad sensor
CamReynolds
CamReynolds
Sounds about right. Parking lot coasting...
Hope so brother, keep us posted!
so my wheel bearing was bad, which made the wheel shake, which made abs come on. all fixed now. hopefully this spell of maintence work is over (axle seal, rotors/pads, bearing, abs).
Multnomah Falls
Your ABS can make a groan noise or what you may think sounds like a fart. I would not think it is a fart noise unless you get that damn smell right along with it. At that point I would blame "organic" brake pad compound as the culprit. But that of course IMO.
CamReynolds
CamReynolds
i thought it sounded like a fart, but its just the abs compressor haha
97ext
