unfortunately I'm in the Northwest but Power Chevrolet screwed me over and sold me the truck for 24k with severe undercarriage corrosion, lesson learned about thouroughly checking vehicle before purchasing for a high dollar.I am so very glad that here in the PNW, we do not have to deal with the rust I see here.
That bolt doesn't turn that much. It's flat on the sides to fit into the alignment cams and rotate them a bit up/down. The nut on the end is what spins 360
Well yeah, lolFyi,
That bolt does turn 360 degrees, you just have to get the alignment washer out off the cam out.
+1. Mine was similar on my 2007 even though I didn't have any rust or difficulty getting the bolt out. It feels like you're pinching those ears together too much when you finally reach the torque spec but that's just how it is.Yep, is bent. It will suck down when you tighten.
Best blades ever!Here is my "shít bird" way of doing it.
You need to cut off the bolt head too, cut it flush to the alignment shim. Then use a large pry bar to bend the bracket ears far enough apart to get a sawzall blade onto the bolt shaft itself on one or both sides. You can always beat them back straight again with the hammer/prybar. (Be careful not to pop out the locating pins/dowels for the alignment plates in this process.) You MAY get enough room to just cut one side of the bolt shaft out and wiggle it out the rest of the way.
I highly recommend using a cutting blade on a grinder, OR your sawzall blades to cut the main part of the a-arm out of the way to give you more room to work those busing pieces out. That will also give you more wiggle room instead of being one rigid piece to fight and work around.
Once you get the a-arm out, a tapered pry bar fits perfect in the bolt hole to help bend back. Don't bother trying to cut through the bushing. The part you circled in blue is not the frame it is the bushing sleeve. The frame part is all flat.
These blades will be your friend.
DIABLO 6 in. 8 TPI Steel Demon AMPED Carbide Reciprocating Saw Blade for Thick Metal Cutting DS0608CFA - The Home Depot
Get an essential and ultimate addition to your drilling performance with this Diablo Steel Demon Carbide-Tipped Thick Metal Cutting Reciprocating Saw Blade.www.homedepot.com
