Scottydoggs
theres back outs and reverse drills, use on a right angle drill working though the wheel well, theres no pressure on the threads being the head is gone, these bolts tend to come out with little effort. seen this go down on yt as well.
its best to remove the exhaust manifold first, then work on removal.
im sure making your own bolt down clamp could also work, just need to copy the one for the newer years. front pass should be the same as the driver side rear. how i see them being sold. used in either or spot for this one, the other two for an different one. point being you should be able to mock up and fab the clamp using the front dimensions. a lot more room to work in.
