Broken Tie Rod
OR VietVet
Multnomah Falls
Military
Willamette Valley
I was actually about to round up spare parts when I started looking at Kryptonite . I'm all for keeping it simple, but in the back of my mind I'm afraid of collateral damage if and when a tie rod decides to call it a day. That could end up costing a lot more, like front diff stuff, ya know? You guys are probably right though.
Typically, the only way you suffer something catastrophic is at speed but if you are crawling or going slow enough, the loss of steering is the damage. I used to own a 73 Blazer that was set up for rock crawling and had one ton set ups front and rear. The only steering component that ever broke while I was doing knarly stuff was the attaching bolts that attached the special adaptor block to account for the lift, at the driver's side steering knuckle. I was able to tighten the remaining bolts and get off the trail and back to camp.
DirtDigler
DirtDigler
I think I should be more concerned with ball joints.
maverick_997
