Brush Guard - 2015 Yukon
bdmcgee
I apologize if this has been previously posted, I did a search and couldn't find any specific information. My question is; has anyone tried to ,mount a brush guard on a 2015? I found company which sells them, but since the 2015 doesn't have tow hooks, you have to CUT to rectangles into the front air-dam to reach the frame rails. I was hoping to find someone who actually has done it. It was an easy install on our 99 Yukon (Big Blue.)
DenaliBQ
i just ordered the two hook cut out plastic trim for the bottom and i ordered a setina push bar for my 2016 spoke to manufacture should be a fairly simple install
bdmcgee
bdmcgee
Thank you for the reply.... I checked the Setina website and they don't show any products for a GMC Yukon, only trucks. Do you have a Yukon? Thanks.
DenaliBQ
yes 2016 i had to call directly they do make one waiting on shipment now
nyc7708ems
NY
I believe the bumper lines are almost the same as a tahoe/suburban so it should be fine but double check with the manufacturer
Tk59194
DenaliBQ, How did the install go? Any photos?
nyc7708ems
NY
not yet still working on it need to modify a little. the mounts line up but you need to drill a couple holes into the frame to run the bolts through where on silverado or sierra they bolts and holes would normally be. Also you will have to cut and trim extra, because of the plastic of the bumper coming all the way down in the plate area and then you will have to cut the trim panel so either the fairlead or hawse lead can be visible and useable. So yes it will work just takes little more work not just simple directly bolt on. Should have more to report on it and a few pictures in that time.
You will need a tow hook kit though
MRAR535
