Do you have a 2021 Yukon? This was a well known issue with the previous generation 2015-2020, but have not heard it mentioned with the 2021's yet.
Not unless you are going up & down high levels of elevation, has nothing to do with the size of the vehicleYes, 2021 (i will update my post).
Not so clear to me if its buffeting though, but slight pressure in my ear., or this is just the feel of having a big suv.
if you really like the vehicle and it bothers you then you could try closing off some of the rear air vents, this will make more pressure when you shut the door but may alleviate the driving pressure. just an idea to try
Does your Denali have a sunroof?Yes, 2021 (i will update my post).
Hey, I am experiencing the same thing, that buffeting noise from outside. I have. 2015 Suburban PPV. Almost seems like your drivers door is not closed all the way. I thought that maybe the weatherstripping was worn out ? I was going to try and fish some small vinyl tubing into the large tubular hole throughout the weatherstripping to see if I can make it stand out more, and see if that helps, but I ran out of warm weather before the snow hit Canada. Anyone else have any ideas, or has replaced the weatherstripping ? It is kind of irritating.
