Buying Used
DuraYuk
Based on my experience of owning multiple baby diesels (both eco & duramax), multiple large diesels (5.9, 6.7, ISM, ISX) and say 20 gas variants (bmw/ram/gm/jeep)
These 3.0 diesels are the most problematic engines available today, 100% hands down.
I've also had many air suspensions fail during warranty, hyper annoying.
Based on my experience you have terrible luck and your experience is unique.
Seamus
Palm Beach
The most problematic??? Just not true. The lifter and main bearings in the 2021+ are the most problematic engine ever to come from GM hands down. Service departments and parts department cant keep up. They are packed with warranty. I have two friends who are GM techs and I ask them about everything we see here. Told me if i want gas dont get anything past a 2020 and delete it in the tune. 2021+ a big no go as per them. So we bought a 2018 Escalade and did an AFM delete in the tune. The 3.0 is very reliable and most have zero issues. He told me of several known issues regarding my 2021 3.0 . Said some are a real pain to diagnose but overall they are a solid motor. ALL modern diesels have issues due to emissions. Some more than others. But its just a general consensus of 3.0 owners its a great powertrain. Many guys well over 100K and not one warranty issue. These gas motors are eating cams at 7K. Saw a brand new escalade in his bay last week...bottom end shot...two months old! If you have had problems with 20 variants of diesels....your the first person I have heard say that. 20 diesels and all were a problem??? Most 3.0 owners get another one or holding onto theirs. Yes few have had issues......but its few.
todayusay
not that I'm against the 3.0, but what's the total # of 3.0s vs the V8s over the past couple years? "few" issues on an engine that represents 10-15% of all powertrains...what's the percentage of "issues" between the two?
my 2 cents would be to stay away from the 6.2 if you're scared of failure, but even with that said, ultimately how many failures have resulted in GM not fixing them under warranty? Sure, being without a vehicle for a month would blow, but everyone's loaner/rental/just using the other vehicle situation is different.
had a 21 AT4 with the 5.3 (45k miles) 22 Z71 with the 5.3 (15k miles) and now a 23 Z71 5.3 with almost 50k...only engine problem on all three was an idler pulley on the 21.
if I had a complete engine failure in the first 5k miles I'd be ticked too
DuraYuk
You make a valid point in terms of total numbers. With that said I don't think there's been hardly any catastrophic lm2/lz0 failures vs gas v8s which are realively common.
Hell I haven't even read or seen a premature oil belt failure either.
The lm2 is also way more common in the trucks so overall numbers are not as small as you think.
But gas v8s are a much larger overall total. Still catastrophic engine blowing in the diesels just hasn't been a relevant thing
StephenPT
St. Helens, OR
This is purely anecdotal evidence - my nearest GMC dealer currently has on their lot or in-transit:
Sierra 1500 - 75 Total (38 Diesel - 37 Gas)
Yukon/XL - 36 Total (28 Diesel - 8 Gas)
If I had to bet I would say the diesel has at a minimum 30% share in the Pickups and SUVs. It very well could be closer to 40%, but I would doubt if it was beyond that.
Our 2006 Yukon Denali has 194000 miles and though we've only needed to replace the torque converter, I can tell there will only be more expensive repairs on the horizon. Would like to get a 2020 or newer Escalade, or a 21 and newer Yukon Denali or an upgraded Tahoe. The 21 and newer Escalades are too expensive at the moment. I`m hesitating because of all the mechanical issues I see when reading the forum. This would be our 4th full size GM SUV, so we want to stay with them if possible. Appreciate any comments. We will most likely pull the trigger on something in the next 45 days. Thanks in advance!
I would go 2018-2020
todayusay
that dealer has almost 5% of all the yukon/XL diesels in the nation
todayusay
here's the tahoe/suburban numbers...
i'd honestly like to test drive one and wouldn't be against one, but we'll have a better idea on reliability in a couple years.
DuraYuk
That's what's in inventory. Gives a small glimpse into what's going on. With that said the lm2 has been out since late 2019. And have not heard much if anything in terms of catastrophic failure or premature/mature oil belt failure.
But you can read about gas failures all day long.
ghettocowboy94
