SunlitComet
OBS Jedi-Do Good
best way I know is use tirerack.com site to find info based on your vehicle Pick your tire selection and look at the specs which will give you all kinds of load and dimensions and you can also choose custom tire sizes and get specs on those too. I put your vehicle with 24 "rims and chose a yokhama advan st and it chose a 305/35R24 tire with these specs:
Load Max. 2469 lbs.
305/35R24
Load Index 112 = 2484lbs (1129kg) per tire
Speed Rating “W” = 168mph (270kph) 112W RF Treadwear: 320
Traction: A
Temperature: A320 A A
32.4 overall diameter
12.3 sectional width
tire weight 47lbs.
Load Max. 2469 lbs.
305/35R24
Traction: A
tire weight 47lbs.
