Cam or Supercharge my 6.0L Denali?
B0$$MAN
Boss of all Bosses
Chicago, IL
I am at that stage where I can't decide what to do in terms of more power!!
My current setup is as follows:
-2002 GMC Yukon Denali 6.0L V8
-200k miles (No leaks, Doesn't burn oil, Doesn't burn coolant)
-AEM Bruteforce Intake
-Jegs Pulley Kit
-OBX Long Tube Headers (No Cats, No Resonators)
-Corsa Touring Exhaust
-Speed Inc. Tune
-Corvette Servo
-TransGo Performance Shift Kits 4L60E-HD2
For a cam setup I would go with this:
-COMP Cams Xtreme RPM Camshafts 54-412-11
-COMP Cams Valve Springs 941-16
-COMP Cams Titanium Valve Spring Retainers 754-16
Anything else you would do while doing a cam install? I don't want a cam that lopes a lot because I don't want it to sound like a drag car or a tug boat haha.
For a supercharger setup I would go with this:
-Radix Magnuson MP112 Supercharger with 11lbs pulley set
This is used as my daily driver. Summer here get pretty hot and humid; 100 degrees+ so I would need it to handle well with the AC on while in traffic and whatnot.
Any suggestions?
Gzes
the drifting 2dr
Wichita tx
Cam first. Imo get a second block and rebuil it with better parts like stronger rods and build it with a cam and then have it ready to swap out and drop the supercharger on later. If this one blows with stock intenrals your done until you find a block
Z-56 Hoe
What do I do????
Houston
If you shop you can find a good LQ4 6.0L block for $350-500 wait and build it better pistons flat top or mild dish pack 1518 springs a cam setup for blower and a convert to deliver power in same area as cam and blower and drop it all in together. You can build a drive-able fun rig just have to be smart about it. And with the amount of miles you have I would not use that block! Get a donor block to freshen up and build off of! My 2 cents!!!
Travieso
Boooooooost !
Los Skandeles, CA
if you're gonna be running 11 lbs of boost on a hot humid day your IAT's are gonna sky rocket, I would recommend Methanol injection, which is the route im going with when i crank up the boost.Im currently at 6 Lbs of boost on a 3.1 Pulley & CAM. These blowers (MP112) are efficient around the range of 6-8 pounds of boost ask me how i know, i own one..
It's all about the Combination of parts, make sure you get a cam that's Boost Friendly.
JennaBear
Resident Ninja
Supporting Vendor
San Diego, CA
Get a blower friendly cam first. I did not want a lopy cam and used my Tahoe for a DD. I ran a 208/212 115LSA. Great blower cam too.
B0$$MAN
B0$$MAN
Boss of all Bosses
Chicago, IL
Thanks Jenna. You've been helping me out a lot via PM. Can you post/send me links to a blower friendly cam for my truck? I'm not too savvy on cams since I've never had to install one on any of my cars/trucks.
Maybe I'll do the cam first and then go from there. I just need some recommendations including springs, retainers, etc...
---------- Post added at 01:53 PM ---------- Previous post was at 01:50 PM ----------
I wish I could go with the TVS1900, but I don't have an electronic throttle body like the 2003+ NBS's have.
Z-56 Hoe
What do I do????
Houston
She just told you what cam. Brand wise I would go either Comp or Texas Speed.
B0$$MAN
B0$$MAN
Boss of all Bosses
Chicago, IL
LOL I totally read over that part. The cam I posted in the first post is a 212/218 114LSA; is that a good cam to run with a blower potentially?
Jongrreat
