camber kit
19964x4HOE
Waterloo, IA
ok so im looking at putting 3" blocks in the rear of my 1996 4x4 tahoe.... What i am wondering is if i crank the torsion bar to try to level it out, will i have to install a camber kit? And if i do what all does a camber kit entail to?
19964x4HOE
Waterloo, IA
Idk if I like rake look on truck... I like the level look. If I get 2" and I crank the torsion bar will I have massive camber?
bowtiefreak
No Quarter
Near Philly
No need, don;t crank to far though. Keep in mnid cranking puts the ball joints and CVs and bad angles and wears them out much faster
19964x4HOE
Waterloo, IA
no need for what? as of right now i just slightly cranked them just to level it out right now... SO what should i do if i do get blocks in the rear..? just little ones
bowtiefreak
No Quarter
Near Philly
no need for a camber kits as per the question that you answered.
If you want the rear higher than it is now and the front to be level with it, look into a real suspension lift.
Welch2324
