Can’t get liftgate to open 3/4 on ‘18 tahoe
clogan2
Very cool. Here’s a vid on how to program. Will have to try it out!!
Wonderful!!!
We've had our 2016 Tahoe dince Aug.2016, and Ive bumped my head on the liftgate countless times. (We keep it set on 3/4 so we can safely open it in our low-ceiling garage.) After reprogramming, no more head bump! WoooHooo!
Thanks, everyone, especially cardude!!!!!
Sent from my XT1254 using Tapatalk
Tylus
South GA
Agreed. I wish I could get mine to go higher. I have to duck my head every time.
reprogram it to a full height setting. I'm 6'3" and when at full height my hatch is nowhere near my head. my 5'4" wife has to jump to grab though lol
Shadow17
So you can increase the height from the initial setting? I know you can adjust the 3/4 height.
I would love if I could get the tailgate to go higher.
Tylus
South GA
Button in cab has 3 settings. Off, 3/4, Max.
3/4 is a setting from factory
The max height can be programmed to whatever you want. There is a video a few posts back showing method. Super easy
Shadow17
I’m a bit slow this morning. The video I watched showed how to program the 3/4 height. I’ll try the steps but pushing upward in the max setting.
dbbd1
No, you can only program the "3/4" setting. But, you can set that one to full opening height.
Shadow17
Which I assume is no higher than the full setting. ???
I’m looking to increase the overall height.
clogan2
If you are tall enough to hit your head on the full open setting, I'll bet doorways are too low, mattresses are always too short, and finding properly tailored clothes is a real problem!
Shadow17
At 6’3” I can walk into it. I need to duck my head.
Sent from my iPad using Tapatalk
clogan2
Something is amiss... I'm six feet even, and can clear the liftgate by at least 6-8" when full open. I clear it by 3-4" in my now reprogrammed "3/4" setting. But then, my Tahoe is 4WD, and sits very high off the ground to start with. If yours is 2WD, or has been lowered, that would certainly account for the lower clearance. Otherwise, I'm wondering if yours is failing to fully open to its maximum designed height? (Maybe that's precisely what you are saying!)
