the 18th letter
Just took my summer wheels off and I'm planning to powder coat but need to clean them up 1st. I found this on eHow and want to know if anyone has used this method? Not sure what color I'm going to coat, hell I may apint them, but this is the 1st step in my process getting them clean.
How to Strip Chrome Off Rims
By Cameron Easey, eHow Contributor
updated: September 3, 2010
Removing chrome from rims involves elbow grease.rims image by Brett Bouwer from Fotolia.comStripping old chrome off rims is a task that you may wish to undertake if you plan to paint or refinish them. Removing the chrome from the rims will, however, require using a bit of elbow grease. Removing the chrome by hand will minimize any damage to the rims that could be caused by use of a power tool. The amount of time and effort needed to complete this task will depend on the size and condition of the rims.
.Difficulty: Moderate
Instructions.Things You'll Need:
Cloths
Wheel polish
600-grit sandpaper
1200-grit sandpaper
Steel wool
Place a fair amount of the wheel polish on a clean cloth and apply it to the first chrome rim.
Sand the rim with the 600-grit sandpaper. Rub the sandpaper over the chrome until it begins to come off. Repeat this process until you have removed most of the chrome.
Wipe the chrome and wheel polish residue off the rim with a clean cloth.
Apply another coat of the wheel polish to the rim with the cloth that you used earlier. Sand the rim with the 1200-grit sandpaper. Rub the sandpaper over the remaining chrome until it comes off.
Wipe the chrome and wheel polish residue off the rim with another clean cloth.
Apply a third coat of the wheel polish to the rim with a clean cloth. Rub steel wool over the rim to remove any scratches that are visible from the sanding. Wipe the rim down with a clean cloth.
Repeat this process to remove the chrome from the remaining rims
Read more: How to Strip Chrome Off Rims | eHow.com http://www.ehow.com/how_6919613_strip-chrome-off-rims.html#ixzz1Apb0XhVw
Cloths
Wheel polish
600-grit sandpaper
1200-grit sandpaper
Steel wool
