Can I replace TPMS sensor without removing tire? (bead breaker...)
trailblazer
Anyone do this using a bead breaker tool like the "Little Buddy"?
Wolfbraid
Winston Salem, NC
I imagine it could be done, not sure what a "little buddy" is. I know we use to replace bad stems at a shop I worked as a teenager, but would use the machine to break the bead and hold it while we removed the old stem.
looked up little buddy, unless you already own it, seems it might be cheaper to find a small shop to help you out.
Hi-psi
Atlanta, GA
To answer your question, yes. But, places like Discount Tire will usually replace the sensor & program (if you already have the replacement) for like $5-10.
Yes, that is how my shop replaces TPMS units (without removing the tire from the wheel).
Wolfbraid
Winston Salem, NC
Thanks for this answer, I know there are two different MHz sensors, how can you tell which you have? I need to order some, as at least one is dead. I figure I'll order 4.
kbuskill
NE. FL.
To my knowledge all '07-'14 trucks use the 315MHz sensors.
kbuskill
NE. FL.
rpo code in your glove box or build sheet will tell you for sure
xl7=315mhz
xl8=433mhz
That's funny... I don't have either code... at least not on the printout I got from GM. I will have to double check my glove box.
Wolfbraid
Winston Salem, NC
Yeah I have to check the glovebox too, at the top of my build sheet it says: " *IVH is not the definitive source of GM Vehicle RPO information..."
richardault
