Can I Tow It
schaffer05
Sorry if my message came across as a scare tactic. I was just shocked that some one actually thought that they could tow a 12k load with a 1/2-ton vehicle. People seem to find a number somewhere on their rig or the internet and use that to justify whatever item they are looking to tow, when in reality every piece of the chain is just as critical.
I hope from the rest of my messages on this thread and other similar ones that have come up you understand that safety in towing is the main reason that I contribute to these threads. Before I purchased either my camper or my Yukon I researched each. Once I found the trailer that I wanted, I set out to find my tow vehicle. That is how I ended up with my Yukon. Last year was our first year out in and the first thing I did was go to a CAT scale to find out my weights and calculate how each of my axles was loaded, the tongue weight, and total combined weight. This past winter I made modifications to my camper, installed larger batteries, installed A/C, flipped the axles for more ground clearance. This year the first thing I did was go get the rig reweighed. Since the geometry and load had changed a little I ended up needing to adjust my weight distributing hitch a little as compared to the previous year.
I hope my input is taken in the spirit that it was given.
I wasn't trying to say you're not right. I get where you're coming from in the safety standpoint. I constantly (on this forum and in the Tundra community) see people mention insurance as a reason why people shouldn't do it. I was just saying that's the last reason, which I'm sure you agree with. Add to the fact that the insurance companies likely would never know the vehicle was overweight.
If I came off as rude or anything, I apologize.
PWMac
Chandler, AZ
Here are some good links with definitions about vehicle weight and tow ratings that helped me.
https://www.your-rv-lifestyle.com/vehicle-weight.html
http://auto.howstuffworks.com/auto-parts/towing/towing-capacity/vehicle /gvwr11.htm
http://auto.howstuffworks.com/auto-parts/towing/towing-capacity/vehicle /curb-weight12.htm
http://auto.howstuffworks.com/auto-parts/towing/towing-capacity/vehicle /gawr11.htm
http://auto.howstuffworks.com/auto-parts/towing/towing-capacity/vehicle /towing-capacity-chart10.htm
I gathered some numbers from my setup and after towing my TT that weighed around 4500 lbs through the mountains of AZ and CO I wouldn't want to go much heavier. The weak link in my chain was my transmission cooler and going up the 6-8% grades the transmission temp got up to 241 and I had to pullover to let it cool down. I ordered a Hayden 679 cooler to install. I would also recommend a brake controller and really like the Hopkins Insight because the manual control was easy to mount within reach and was nice for going down the mountains.
2008 Yukon XL Denali AWD 6.2L 3.42 gears
Yukon XL Gross Vehicle Weight Rating GVWR 7200 lbs
Yukon XL Gross Combined Weight Rating GCWR 13,000 lbs
Yukon XL Gross Axle Weight Rating GAWR Front 3300 lbs Rear 4200 lbs
Yukon XL curb weight 5608 lbs
Yukon XL towing capacity 7100 lbs
Yukon XL max cargo 1300 lbs
Trailer Gross Vehicle Weight Rating GVWR 5000 lbs
Trailer Gross Axle Weight Rating GAWR 5080 lbs
Trailer unloaded vehicle weight UVW 4012 lbs
Trailer cargo carrying capacity CCC 705 lbs
Weight Distributing Hitch tongue weight 1000 lbs
Weight Distributing Hitch max weight 10,000 lbs
2" ball 7500 lbs
Yukon xl curb weight towing capacity would be 7100 lbs.
If yukon xl loaded to GVWR of 7200 lbs towing capacity would be 5800 lbs.
For me I think the max I would try towing any kind of distance or grade would be 6000 lbs and probably try to stay closer to 5000 lbs.
M3kanic
It still sits a little tounge high but I'm at the bottom of the hitch. One of these days I will get it in a scale to find out all of my axle wieghts.
Yep, I see that now, move some camp chairs and cast iron cookware towards the front? Or whatever is in back of your truck to the front of the trailer?
radmann07
