Can NE1 run a GMVIS report for me?
doubletapdrew
Can someone run this vin 3gnek13t12g179330, looking at adding to the stable..
Thanks,
Vehicle Information
VIN: 3GNEK13T12G179330 Model: CK15936-2002 AVALANCHE 4WD
Service Contract: No Branded Title: No Warranty Block: No PDI Status: No
Order Type: 70 - RETAIL - STOCK
Field Actions: 0 Open
Required Field Actions Open field actions are highlighted
Type Number Original Nbr Description Release Date Status
Product Safety Recall N040007 04007 TAILGATE SUPPORT CABLE 09/17/2004 Closed
Branded Title
*The VIN information contained herein and information derived therefrom is the proprietary property of The Polk Company and is to be used only for the purpose of warranty verification and shall not be used for any other purpose whatsoever.
Vehicle has no current record of branded titles.
Warranty Block
Vehicle has no current record of warranty block.
Service Information
Vehicle has no current record of outstanding service information.
OnStar and XM Satellite Radio Information
Vehicle has no current record of OnStar / XM Radio information.
Applicable Warranties Valid warranties are highlighted
Valid Description Start Date Effective Odometer End Date End Odometer
Corrosion Limited Warranty 07/22/2002 15 MI 07/22/2008 100,015 MI
Emission Select Component Ltd Wty 07/22/2002 15 MI 07/22/2010 80,015 MI
Bumper to Bumper Limited Warranty 07/22/2002 15 MI 07/22/2005 36,015 MI
Service Contract
Vehicle has no current record of service contracts.
Transaction History View Details
Job Card Date Job Card Number Transaction Type Transaction Adjustment Labour Operation Odometer Reading
04/29/2005 124160 ZFAT----Field Action Recall V1242 - 04007 - Inspect and Replace Tailgate Support Cables inc. Hinge Replacement if Necessary 84,540 MI
04/29/2005 124161 ZREG----Regular Vehicle Transaction A2930 - Tailgate, Complete - Refinish/Clear Coat 84,540 MI
11/18/2003 023722 ZSCT----Service Contracts J4100 - Generator Replacement 59,305 MI
11/18/2003 023722 ZSCT----Service Contracts N2328 - Switch - Ignition/Key Warning - Replace 59,305 MI
11/08/2003 023604 ZSCT----Service Contracts K6557 - Torque Converter Clutch Pulse Width Modulation Solenoid Valve Replacement 55,334 MI
09/08/2003 022780 ZSCT----Service Contracts E2327 - Front Wheel Bearing and Hub Replacement - Both Sides 50,434 MI
09/08/2003 022780 ZSCT----Service Contracts F2122 - Carrier Assembly - Front Differential - R&R 50,434 MI
09/08/2003 022780 ZSCT----Service Contracts F2283 - Differential Drive Pinion Gear Bearing Replacement 50,434 MI
09/08/2003 022780 ZSCT----Service Contracts Z7902 - 2-DAY COURTESY TRANSPORTATION 50,434 MI
07/22/2003 022140 ZSCT----Service Contracts Z7902 - 2-DAY COURTESY TRANSPORTATION 44,791 MI
07/22/2003 022140 ZSCT----Service Contracts D2822 - Heater Core Replacement 44,791 MI
03/12/2003 020317 ZREG----Regular Vehicle Transaction F1280 - Propeller Shaft Assembly - R&R Or Replace 31,401 MI
12/20/2002 018978 ZREG----Regular Vehicle Transaction C0660 - Rear Window Replacement 23,036 MI
11/15/2002 018467 ZREG----Regular Vehicle Transaction B9612 - Front Fog Lamp Replacement 14,869 MI
11/15/2002 018467 ZREG----Regular Vehicle Transaction B9613 - Front Fog Lamp Replacement - Left Side 14,869 MI
11/01/2002 018249 ZREG----Regular Vehicle Transaction E0620 - Jack Replacement 13,199 MI
11/01/2002 018249 ZREG----Regular Vehicle Transaction B9616 - Parking and Turn Signal Lamp Replacement 13,199 MI
10/04/2001 A79330 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
kskcheche
Could you run a couple vins for me?
2GCEK13Y471508266
1GNUKDDJOAR222743
Thanks a million!
doubletapdrew
2GCEK13Y471508266
1GNUKDDJOAR222743
Thanks a million!
Vehicle Information
VIN: 2GCEK13Y471508266 Model: CK10543-2007 SILVERADO 1500 4WD CREW CAB
Field Actions: 1 Open
Customer Satisfaction Program N090184 09184 MATERIAL OVER SENSING & DIAGNOSTIC MODULE RETAINING MOISTURE 10/19/2009 Closed
Product Safety Recall N080048 08048 HEATED WINDSHIELD WASHER MODULE SHORT CIRCUIT - ADD WIRE HARNESS 08/28/2008 Closed
Product Safety Recall N100153 10153 HEATED WINDSHIELD WASHER MODULE SHORT CIRCUIT - DISABLE AND REMOVE MODULE 06/08/2010 Closed
Service Update Bulletins N070033 07033 SERVICE UPDATE - INVENTORY & CUST. VEHS-BATTERY RUNDOWN-*EXP W/BASE WARRANTY* 02/06/2007 Open
Branded Title
Warranty Block
Service Information
Refer to Help page for details. For OnStar contact 888.ON.STAR1 (888.667.8271) and for XM Radio contact 877.GET.XMST (877.438.9677 Canada) and in the USA:800-556-3600.
OnStar Equipped: Y OnStar Status: Inactive
XM Equipped: Y XM Radio ID: NNELL0HL XM Status: Active
OnStar Vehicle Diagnostics: N DMN Enabled: N
Bumper to Bumper Limited Warranty 02/28/2007 50 MI 02/28/2010 36,050 MI
Corrosion Limited Warranty 02/28/2007 50 MI 02/28/2013 100,050 MI
Emission Select Component Ltd Wty 02/28/2007 50 MI 02/28/2015 80,050 MI
Powertrain Limited Warranty 02/28/2007 50 MI 02/28/2012 100,050 MI
Special Coverage 09239 02/28/2007 50 MI 02/28/2017 100,050 MI
Service Contract
04/22/2013 6023548 ZFAT----Field Action Recall V2283 - 10153-Windshield Washer Solvent Heater Asm Removal - No Check Issued (Veh in Dlr New/Used Inventory) 115,056 MI
04/22/2013 6023548 ZFAT----Field Action Recall V2133 - 09184 - SDM Corrosion - Remove acoustical pad from the SDM area 115,056 MI
02/03/2009 046831 ZFAT----Field Action Recall V1993 - 08048A - Jumper Harness Installation 33,884 MI
10/18/2006 A08266 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
---------- Post added at 10:46 AM ---------- Previous post was at 10:45 AM ----------
Vehicle Information
VIN: 1GNUKDDJ0AR222743 Model: CK10706-2010 TAHOE 1500 4WD
Service Contract: No Branded Title: No Warranty Block: No PDI Status: Yes
Order Type: 81 - DEALER USED CAR (CVMS USE)
Vehicle has no current record of required field actions.
Branded Title
Warranty Block
Service Information
XM Equipped: Y XM Radio ID: C70W52MT XM Status: Active
Emission Limited Warranty 04/27/2010 0 MI 04/27/2013 50,000 MI
Corrosion Limited Warranty 04/27/2010 0 MI 04/27/2016 100,000 MI
Emission Select Component Ltd Wty 04/27/2010 0 MI 04/27/2018 80,000 MI
Hybrid Component Limited Warranty 04/27/2010 0 MI 04/27/2018 100,000 MI
Bumper to Bumper Limited Warranty 04/27/2010 0 MI 04/27/2013 36,000 MI
Emission Select State Component Lty Wty 04/27/2010 0 MI 04/27/2017 70,000 MI
Powertrain Limited Warranty 04/27/2010 0 MI 04/27/2015 100,000 MI
Certified Used Limited Warranty 04/27/2010 0 MI 04/27/2014 48,000 MI
Special Coverage 11273 04/27/2010 0 MI 04/27/2020 120,000 MI
Service Contract
09/16/2013 33555 ZREG----Regular Vehicle Transaction Add Credit 4066070 - Oil Pump Replacement 77,854 MI
09/16/2013 33555 ZREG----Regular Vehicle Transaction Full Debit - Reversal 4066070 - Oil Pump Replacement 77,854 MI
09/16/2013 33555 ZREG----Regular Vehicle Transaction 4066070 - Oil Pump Replacement 77,854 MI
09/15/2013 0012475629 ZREG----Regular Vehicle Transaction 0600022 - ROADSIDE SERVICE (TOWING) 77,000 MI
05/21/2012 01-58649 ZREG----Regular Vehicle Transaction E9994 - Customer Concern Not Duplicated (CCND) - Steering 46,230 MI
04/09/2010 A22743 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 1 MI
harveje
harveje
Thanks,
I actually passed on that one due to the mileage report didn't match current odometer and owner called me a lier ....
But I did get one
can you run
3gnek12t14g328016
Thank you :cheers:
Trixxterr
Jax, Fla
Hmm, I'm curious. How far back can you go?! Have a Silverado, that I have ZERO info on. Things have been changed on it. I wanna know what it originally came with. I do have the vin. Is an 80 Silverado too old?!
Also, how does a normal guy get access to these records. Or just dealers,
doubletapdrew
Thanks,
But I did get one
can you run
3gnek12t14g328016
Thank you :cheers:
Vehicle Information
VIN: 3GNEK12T14G328016 Model: CK15936-2004 AVALANCHE 4WD
Service Contract: No Branded Title: Yes Warranty Block: Yes PDI Status: No
Product Safety Recall N050037 05037 SECOND ROW CENTER SAFETY BELT 07/14/2005 Closed
Branded Title
Brand Description: SALVAGED Date Branded: 08/01/2009
Title Number: C33610602 Reporting Source Code:
Reported By: MS Effective Date: 02/26/2011
Warranty Block
Code Description Effective Date
BT BRANDED TITLE 09/11/2009
Block Transaction Types:
ZPDI
ZPTI
ZREG
ZSCT
Blocked Labour Ops:
Service Information
XM Equipped: Y XM Radio ID: 6V7760R3 XM Status: Active
Bumper to Bumper Limited Warranty 08/05/2004 120 MI 08/05/2007 36,120 MI
Emission Select Component Ltd Wty 08/05/2004 120 MI 08/05/2012 80,120 MI
Corrosion Limited Warranty 08/05/2004 120 MI 08/05/2010 100,120 MI
Special Coverage-07187 08/05/2004 120 MI 08/05/2011 80,120 MI
Service Contract
06/27/2006 028748 ZFAT----Field Action Recall V1382 - 05037 - Stitch Seat Loop Closed 42,447 MI
06/28/2004 A28016 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
---------- Post added at 08:32 AM ---------- Previous post was at 08:29 AM ----------
I'm not sure how far back it'll go. Sent me the VIN and I'll try it.
You have to be a dealer
doubletapdrew
Well, its worth a shot I suppose.
CCG44AS159455
You're a few digits short. It has to be 8 or 17 digits
I take it this isn't the right one:
Vehicle Information
VIN: LSGJA52UXAS159455 Model: 4JY19-2010 Buick-1.6 LE and Buick-1.6 LE AT
Order Type: N/A
Branded Title
Warranty Block
Service Information
SGM Special Power Train 57mo/160km 09/18/2010 0 KM 06/18/2015 160,000 KM
SGM Bumper to Bumper 24/60 09/18/2010 0 KM 09/18/2012 60,000 KM
Service Contract
02/08/2011 ARO11020120 ZSSP----Special Sales Programs Z0062 - Free Oil Change 2,732 KM
lmg_1681
