Eschrichtius
- Joined
- Oct 31, 2011
- Posts
- 31
- Reaction score
- 2
Just an update, still no CEL code. Everything's working great and MPG is back where it supposed to be
I’ve been fighting P0430 for weeks now on my 2015 Tahoe . I’ve replaced both cats and all 4 oxygen sensors as well as all coils, plugs and wires. Cleared code and it comes back a couple of days later. Truck runs fine just have no clue why it won’t stay off for good. Had the fuels trims reset and that didn’t work
I’m told by dealer that the o2 needs to be programmed after being replacedThere are several reasons for a P0430. The most obvious is a failed cat, even a new one. A large exhaust leak can set the code, such as a leaking exhaust manifold.
Aftermarket cats and O2 sensors don't play nice with the computer and they will set varying codes.
Finally, when the troubleshooting guide has been exhausted, it's usually time for a new ECM.
A new cat will often set a code within the break-in period, usually a hundred miles or so.
Yea denso is what I put on my truck. Truck runs great but the damn light won’t go away. It’s being “reprogrammed” tomorrow so by Friday I’ll know if it worked or not. I live in NY and been trying to get my truck inspected for almost 2 months with no luck because of that stupid code. I can look at live stream and everything reads normal, even when the check engine light comes back on. So I’ll post back Thursday or Friday, if it makes it to Monday then it’s getting inspectedit's been talked about here. technically you could call it that. the o2 has a heater circuit in them and the ecm controls that with a pwm ground circuit. it needs what's called a heater reset.
but unlike normal module replacement that need progammed using gm's dealer software. when you clear the codes with a standard obd2 scanner it clears the heater data and the ecm goes thru a recal automatically.
the annoying part is the o2 itself. 99% of trucks will be fine with any old brand o2. but some seem to not work correctly with anything but oem. and not even ones made by denso, which is believed to be the oem manufacture of the gm part, but the actual gm part number o2. why, I don't pretend to know and tons of people can throw any old cheap auto parts store o2 in them and never give a 2nd thought. others it seems to be an issue.
and I didn't need a scanner/programmer when I changed mine. 100% plug & play.I’m told by dealer that the o2 needs to be programmed after being replaced
