Can you remove the front Drive Shaft
abishoff
on my 06 Denali, the front diff has a terrible humming noise. Is it ok from me to drive around without the front drive shaft for awhile, to confirm its the front diff? I was gonna pull it from the diff to t-case
Duramax05blk
NH
No will cause a lot worse of problems
Sent from my SM-G900V using Tapatalk
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
If your trying to isolate a noise yes you can. Would not recommend leaving it not leaving it like that for long period of time.
Duramax05blk
NH
Good luck let me know how it works.. I was mistaken earlier it won't cause problems because it won't move.
A
abishoff
Yes I wasn't to remove the drive shaft from the T-Case to the front diff and drive it around. How long can I drive like that?
Duramax05blk
NH
Because its an all wheel drive transfer case. It will send all power to front with shaft removed. Your most likely hearing differential bearings
wiser1
