Can't Remove Luggage Rack ?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
double side tape. and the are not load bearing the typical sense of the word. it is save your paint from abrasive damage and shifting side to side.
_Dylan_
STAY FROSTY
This is so funny. I tried getting an escalade roof rack from a junkyard today and I couldn't get the bolts out in the center of the bars. I cut holes in the headliner and I couldn't get a wrench on the bolts. Stupid GM.
Maybe I missed something, but I don't think the center bolts are accessible from the top on a Denali/escalade.
Sentry
Uh, if you continue this and pull down the head liner. I would like to see pics if you would... Especially of what the hole look like from underneath...
I did remove my luggage rack... Not good. I broke two of the bolts in the holes. Then not thinking it through, I used a 1/4 inch bit to drill through them. That was with the intent of taping the hole and using a new screw.
The bolts are 8mm, which is less than 1/4"...
Basically, I need all new bolt points. No roof rack for me until then.
BE CAREFUL!
tri94sbc
Oswego, N.Y.
I was thinking of removing my roof racks on purpose. I thought it might look better. I have no intention of carrying anything on the top.
95escahoe
Looks alot better without the rack heres mine
Sent from my HTC One X using Tapatalk 2
SunlitComet
OBS Jedi-Do Good
Sometimes the riv-nuts lose their grip on the roof metal and with the bolts maybe a bit stuck too all you do it just spin the whole assembly around. just use a tool to slightly grip the bottom of riv-nut as needed to extract the bolt.
EBALLEN28
