Cargo area window size question
dmannx
Carlsbad, CA
Why is the passenger side cargo area window on a Tahoe smaller than the driver side. They look the same from the outside - but when viewed from inside the cargo area the size difference is obvious. there is more of a pillar separating the window and the backseat passenger door.
Just wondering ???
trdhulk
another question to ask would be why is there only defrost on one side and not the other?
Goodinblack
I Like Tacos
Dirty South
That is NOT defrost, that there be your Antennr fer yer Radio.
Ever wonder why you have no steel antenna on the fender? The shark tale on the roof is your XM Onstar.
Also, when tinting that window avoid a "metallic" window film. It will cause problems with reception. That is why they have ceramic or plain film. I avoided tinting that window altogether because once the tint scratches and you have to redo it, there goes your antenna in the removal process.
The window is smaller on my Suburban I think because of the ducting for the Rear AC.
yashchitre
