Caution Switch
Tjhb
My caution light switch is not working but my turn signals do. Is there different flasher modules or are they the same? And if they are the same what is the easiest wayou to replace the flasher switch? Would I have to rake apart the whole steering column? Thanks for the help in advance!
Did you check your manual? I'm not positive, but I think the hazard relay/module should be under the dash near the column. Should be different then your blinkers.
MrBalll
West Texas
Not sure if this will help you, but my right signal worked when it felt like it and the hazards worked when it felt like it. After awhile they both completely went out. So I replaced the flasher and both work fine.
Not sure if this would help you, but it's something to look at.
I know this is old but wasn't sure if you solved your problem or not yet.
Lilmule
