Question!!! is there anyway to pull error codes form an 06 chevy tahoe without hooking it up to an obdII scanner. I got a check engine light when I started my truck up this morning. the dic said reduced engine power. so i turned it off then started it back up and only got the CEL. it drove fine. I dont own a scanner so i was wondering if there is another way to pull codes. I have a dodge magnum and there is this process called a key dance which will give you any error codes. is there anything similar to that for a chevy tahoe.
