BlueTahoe2001
So basically LS1 Parts will fit? If thats the case I have a friends who's dad is over the GM High Performance section I Might be able to get some stuff...
found the cam it had... yeah and MTI X1 lol. 230/227 .591/.571 112lsa... not a big cam but a paired with big heads and 1 7/8th primary headers will do it
Just got through helping out with a LS7 swap into a slammed Tahoe. Just a tune away from bliss now.
The guy bought a used LS7 and pulled his motor out of his Tahoe (he spun a bearing), used his oil pan and converted everything to a wet sump system from the LS7's dry sump setup. We used all of his original electronics, coils, sensors etc., and he bought an aftermarket 90mm TB. The reluctor wheel on the crank is 58X instead of 24X so we used a Lingenfelter Performance reluctor wheel/trigger wheel electronic adapter module. It allows Gen IV GM V8 engines with the 58x crankshaft trigger or reluctor wheel and the 4x camshaft timing gear to be installed in earlier vehicles designed to accept the 24x crankshaft trigger wheel and the 1x camshaft trigger wheel. So far so good, just need to tune via EFI live for the injector size and then get on a dyno and tune.
As far as a cam, you can make just about any one fit, just make sure you check valve to piston clearance and/or notch your pistons with a piston notching tool from Isky or any other. Patriot makes great heads for the 4.8/5.3: https://www.patriot-performance.com/xcart/product.php?productid=38&cat=36&page=1 but, if you want the absolute best for your money TEA has it all. Check out the flow numbers http://www.totalengineairflow.com/products/gmhead/gmls1/
