changed 02 sensor, plugs and wires still got ses light ?
johnnunez29
this truck is driving me nuts! i changed all the plugs and cables, iridium plugs and changed the sensor! before the cat but my truck is still getting the po420 code. im confused as hell truck is no longer boggy at idle but code re popped up. anyone know what else it can be? where to look? thanks
yukondoit
Stay Classy
Flagstaff, AZ
Did you clear the code? Thats usually the way to get rid of the code. If it comes back after you clear it, then there might be another problem.
mason313
exaust leak or maybe the cats could be clogged
J
johnnunez29
Try starting here. Disconnect battery for at least 5 minutes.
i took it to autozone and they cleared the code for me. then it rode for almost a hole day no light then bam! lol. cant be a misfire but can be an exhaust leak or maybe bad cats or even oil in exhaust ... does or has anyone had this issue?
Rivieraracing
Is it the same code?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
They have two per cylinder bank so for total of four. One before and after each converter on your vehicle. Your specific code says the left cylinder bank converter is not doing it cleaning job chemically speaking. A dAmaged sensor, bad converter(which is what the code is for) or screwy pcm can cause this code.
http://www.obd-codes.com/p0420
J
johnnunez29
i had seen this and went through it. how do i test cats? i changed the driver side top o2 sensor and all plugs. seemed fine til yesterday afternoon. and whats a pcm? thanks btw
scrtcell
Had the exact same problem your cat on the drivers side is bad once you replace that all your troubles will go away...
morrisonm
