Hi have to change the coolant in a 2004 Tahoe z71 with rear heat. In order to properly drain the truck, do i need to do anything to open up valves for heater core (front and rear) prior or during draining?
The FSM says to pull the lower radiator hose off radiator. I have also seen posts about a valve to open on radiator? I looked for valve but did not see anything. Is the lower radiator hose best option?
I picked up an AirLift system for draining the truck. Should make life easier.
