changing door/dome lights
Danzigman
Galveston, TX
I did this conversion as well using Superbrightleds. The only issue I came across was that the front lights (map lights) that they recommend are not bright enough. I selected a buld with more leds to fix this problem, otherwise no problems at all. I did it about a year ago and have had zero issues.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
I use Superbrightleds 99% of the time and have had no problem with them. Every once in a while I'll get a bulb blinking or going bad, and the swap them out for free if it's within 1 year
Ls1leadfoot
Ls1leadfoot
well thanks for the opinions fellas, im glad ive been using them for past lights
will continue to use them now
DANZIGMAN
could you please give me the bulb number or discription so i can aviod the problem you had ;-)
Danzigman
Galveston, TX
It is the 194 maplight bulb. I just took a look at the site, you can go by the bulb intensity scale now. I don't remember seeing that as promenantly before. WLED-xHP5 is what I ended up going with. It is a little bright, but I like it.
Ls1leadfoot
Ls1leadfoot
Awesome man thanks for that info
Ill be ordering this Friday
Will do the install and post pics of mine, your welcome to post some of your as well
dylanrog24
