changing tie rod ends
ezdaar
Chat Troll
Redneck central, Aka Houston
shock is crooked. you got something else wrong.
And please for future sake, make sure your images are not a blurry mess.. ala second image... Why did you even post that? :Nonono:
O
Oldyukon95
My camera wouldn't focus. And the pic worked well enough to illustrate my point.
OR VietVet
Multnomah Falls
Military
Willamette Valley
Not according to Doug. The pic only has some meaning because of the story that comes with it. Plus you know what you are looking at. The other pic helps more and is great.
O
Oldyukon95
Ron thanks for your help. When I bolted the top first and Jacked up the control arm the strut went right in. 5-10 min. Next I will be getting new tires and an alignment!
OR VietVet
Multnomah Falls
Military
Willamette Valley
That's why the bolt sleeves at each end of the shock are mounted in rubber so the arm can deflect up and down and the shock can expand or contract and still "flex" instead of just breaking the ends off. Make sure the shop that does the alignment checks the front end, steering/suspension, thoroughly so the alignment actually accomplishes something. Is best to get a before and after printout from the shop and post those readings on here.
O
Oldyukon95
I'm getting tires and an alignment today. I'll let you know how it turns out.
O
Oldyukon95
Here's my new tires and the results from my alignment. They did mention that I have a lot of play in my gear box. But it's still about 2 inches from left to right. I guses that's next. and they said my brakes pulsate. I never even noticed
OR VietVet
Multnomah Falls
Military
Willamette Valley
From what I could see or make out from the alignment readings you do have a little higher caster on the right front which is good.
O
Oldyukon95
That picture isn't that great either. Sorry, I think I have a better one on my other thread
Meg_az19
