DESIGN
Hey guys,
2003 4.8 2WD Tahoe. Water pump is leaking and although it might just be the seals with just over a 100K on it I am replacing the whole thing tomorrow. Good chance to do some other things like the obvious flush/fill, belts, and thermostat while I'm in there.
My question is this, do you need to remove the Fan in order to remove the pump or is there enough room with the fan still on there? I'm trying to plan out everything and want to know if I should rent the fan clutch removal tool from the store.
Also if you guys know of a good write up (pictures would be great) could you post up the link? I've search and either I suck real bad at it or nothing was out there.
Thanks,
Jon
Thanks,
Jon
