changing wheel bearing
highrollin113
Undercover
Edmonton, Alberta, Canada
does anyone know the size of nut for the wheel bearing so i can get the proper socket or does anyone know of another tool? its an al wheel drive 04 yukon front left bearing
thanks for help
Administrator
On my 07 it's like a 32mm nut. Not sure if it'd be the same for yours. Do you happen to have a haynes manual or a chiltons?
Administrator
Another thing you could do is go on autozone.com and act like you were going to buy that nut and see how big it is according to the description :waytogo:
MASS-HOE'Z71
Mass
95% certain that the axle nut is a 36mm and the 3 surrounding bolts are a 17mm or a 19mm, it has been awhile since I did mine though.
I'd have a 17, 19, 35 and a 36 mm on hand, plus what you need for the calipers, you should be fine
highrollin113
highrollin113
Undercover
ya i found a how to write up on google but for a denali but they said 36mm and the hub assembly part number is the same so i am going to go with that, thx you guys, thats why i love this site
Administrator
:waytogo:
91RS
GA
The axle nut is 36mm and the bolts that hold the hub on are 15mm.
Munyon91
