Cheap fix for a door panel screw up?
Gzes
the drifting 2dr
Wichita tx
I think plastic weld will work just get it hot enough to bond. I had to remake where my under column panel goes and it turned out great. I used zip ties as the material and a torch and metal strip as the heatin element
FishinCricket
FishinCricket
GMC Salesman
The Ozarks
The offending part.. I may as well try and epoxy it first, see what happens...
YukonXL04
The Riverboat
Arlington, TX
It will probably hold as long as you don't take that panel off ever again lol. Good luck. I hope OT works for you
FishinCricket
FishinCricket
GMC Salesman
The Ozarks
Luckily for me I've got access to a body shop and the stuff I used is the same stuff they use to deal body panels together...
Still feel free to wish me luck though. lol
---------- Post added at 02:29 PM ---------- Previous post was at 01:58 PM ----------
The epoxy appears to have done the job! :). This 3M stuff:
YukonXL04
The Riverboat
Arlington, TX
You could try cutting a piece of thin metal to cover it, spread the epoxy all over, lay your metal down then after if dries cut the slot back out and that should hold.
FishinCricket
FishinCricket
GMC Salesman
The Ozarks
Yeah, that's what I was thinkin...
For now I double sided sticky taped that lil bastid.. It'll hold for now.
Jlaughtr
Deming, NM
I have broken the same piece just from using the door handle to shut the door i guess. Can you not just buy the piece or do you have to buy the whole door panel? I'm even thinking of just running an epoxy or glue on the rim of the panel and just sticking it on there without using the clip..
Ginja087
